WIP section. All about personal works, renderings, WIPs
 1-11  12-31  32-36
Hi everyone!
Little quick and dirt render while learning InstantLight.
Workflow : Moi (for the base concept), 3D-Coat (voxelization, retopo, painting), InstantLight (GI realtime rendering)
All effects (bloom, noise, dirty, GI, shadows, LUT...) are in realtime.
This is the low-res rendering :
Here's the 4K version : http://take.ms/Sf7tR
Here's the starting base concept in Moi :
Bye!
Marco (mkdm)
Hi everyone!
I had some fun with the topic posted by @AndrewG at http://moi3d.com/forum/index.php?webtag=MOI&msg=8554.1
So I made some modelling test based also on an idea taken from @BurrMan (http://moi3d.com/forum/index.php?webtag=MOI&msg=8554.14)
and I created my very personal interpretation.
Here's the 3dm file : https://monosnap.com/file/pvrsQIISEbsC3JGGVXbyhQcsNt1Ado
(All objects are perfect solids inside Moi.)
Here are some Moi's screen shots :
And here's the 3DCoat quick render :
(full size : https://monosnap.com/file/VrAzEmY8H2caymDjleSmNCj13hMc5H)
Bye!
Hi everyone!
Going further into practicing with the superfast workflow : Moi -> 3D-Coat
This is my latest concept : "Metal ET Plant"
Here's the 3dm file : http://take.ms/o3UQO
Here's the Moi's screen capture :
Here's the 3D-Coat quick render. Full scene is about 22 Mil polygons in voxel mode.
NO UV NO RETOPO, ONLY VERTEX SHADERS.
Here's the hires version :
https://monosnap.com/file/uhk8QbHJaW0wetNPjMZdfmVFZY0SIz.png
From scratch to finish, including final composition in Affinity Photo, about 3 hours.
Bye!
8525.35 In reply to 8525.34
P.S. As you can see the perspective is exaggerated with a great FOV value inside 3DCoat.
Hi everyone!
Taking inspiration from this thread of AlexPolo (http://moi3d.com/forum/index.php?webtag=MOI&msg=8587.1) I have created these objects in Moi.
The starting model was a simple extruded disc with two circular holes.
I have modified the starting model in several ways.
Final renderings in 3D-Coat with Vertex Shader.
This is the 3dm file : http://take.ms/aU3jI
and these are the rendered objects :
Bye!
Show messages:  1-11  12-31  32-36
