i need suggestion for modeling shape
All  1-4  5-9
8520.5 In reply to 8520.4
Hi PaQ, thank you so much. this is work just fine. i would like to see if Michael have another way to do this just for learning only for me what PaQ do work fine for me it's just little bit treky when it come to filleting edge the green one in PaQ Image but i figure it out. thank you guys
8520.6 In reply to 8520.5
Hi albehany.
Congratulation for your portfolio. Wonderful stuff!!
Bye.
8520.7 In reply to 8520.5
Hi albehany, there are likely to be other ways but my first thought was along the same lines that PaQ showed with building a full shape then cutting it in half rather than trying to build the half by itself. It tends to be easier to get better surface quality when you're able to use a simpler layout for the surface construction. The more you try to force a surface to go directly along an oddly shaped or cramped boundary the more likely it is that you'll get wrinkles and bumps in things as various shapes try to come together and fight with each other.
8520.8 In reply to 8520.6
thank you Marco for the nice word.
8520.9 In reply to 8520.7
thank you Michael really appreciate your help.
Show messages: All  1-4  5-9
