Flow in 2 directions
All  1  2-3
8514.2 In reply to 8514.1
Hi Stardust, usually for doing a flow in 2 directions you can use surface-to-surface flow instead of curve-to-curve flow. You would build a sweep or whatever to build a curved target surface and have a plane as your base surface instead of a line.
But it could be possible to make a script that would do curve-to-curve flow twice by picking 2 target curves.
It would help if you could post the 3DM model file of what you show there for your example instead of only a screenshot, that way I could test with your file to see if the script is doing what you were expecting.
8514.3 In reply to 8514.2
Thanks Michael
And thank you for reminding me of surface to surface flow, works like a charm and gives much better control of the final shape.
(No need for new script of curve flow :)
/Stardust
*Michael for Nobel Prize*
Show messages: All  1  2-3
