Moving specific locations to x,y,z 0,0,0
All  1-2  3-5
8507.3 In reply to 8507.1
Hi Bob, yes you can use the Transform > Move command to do that. First select your objects and then run Transform > Move.
The Move command takes 2 points, you first pick the point you're moving from and then you pick the point you're moving to.
When you're at the first stage for picking the point you're moving from, there's a button labeled "Bounding box center" which you can push to use the object's bounding box center as the base point:
So you'll want to use that for your base point. For picking the target point, you can type in x,y,z values for any point pick and you can type in just plain 0 as a shortcut for 0,0,0 . So for the target point pick type 0 and then push Enter to specify 0,0,0 there.
8507.4
Thanks, Michael
Will give suggestions a try. Appreciate the response....Bob
8507.5 In reply to 8507.2
Thanks, Frenchy ... I'll load up the routine...sure will make my work much easier...Bob
Show messages: All  1-2  3-5
