Suggestion : Distribute objects
 1-17  18-37  38-53
8503.38 In reply to 8503.37
Hi Marek, thanks for the example file.
I've updated the Distribute command at:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8503.13
It now has a "Set length" checkbox option and if you set it, a "Length" field will appear where you can enter in an overall length value.
8503.39 In reply to 8503.38
That's it.
Thank you Michael,
Marek
8503.40 In reply to 8503.38
Seems there is a glitch on your new command Distribute when you define a length!
Cubes are 10 * 10 * 10 !
At the end there are all on the same place! ???
EDITED: 3 Jun 2022 by PILOU
8503.41 In reply to 8503.40
It looks like you're giving it an invalid length, your length is shorter than the width of the objects.
The command is for distributing objects with even spacing between them across a length. If your length is less than the total width of the objects then it is not possible to do that.
8503.42 In reply to 8503.40
If the distribution length is 1/3 of one object width it looks like this, so another option would be picking the distance instead of putting in numerical value.
And watching how it changes, before the final click.
8503.43 In reply to 8503.40
> Cubes are 10 * 10 *10 !
Then your length should be a minimum of 30 for 3 such cubes to be able to fit with 0 space between them. As you go larger than 30 then there will be spacing added between them.
8503.44 In reply to 8503.43
< As you go larger than 30 then there will be spacing added between them.
OK ! Was not evident at first view! :)
Confusion (for me) between "on a length" and "absolute distance" between object...
that is an another one existing...
8503.45 In reply to 8503.42
It could be another 1D Scale but limited to the Distance not the objects.
8503.46 In reply to 8503.38
Is it a big deal to have in MoI a Scale option as in ScalePositions in Rhino?
Situation when you have several objects and you want to scale a space between them not the objects?
In Rhino it is even a polar option for objects arrayed circular.
Marek
8503.47 In reply to 8503.46
Hi Marek,
Is it like the ExplodeMove command in Moi?
https://moi3d.com/4.0/docs/moi_command_reference10.htm#explodemove
https://moi3d.com/forum/index.php?webtag=MOI&msg=10060.6
8503.48 In reply to 8503.47
No, not at all:
see this, please:
https://youtu.be/uqOJP1NAJMI?t=511
Marek
8503.49 In reply to 8503.48
Hi Marek,
> No, not at all:
> see this, please:
That is doing the same thing as ExplodeMove in MoI.
Here's a demonstration, compare the result to the video you linked:
8503.50 In reply to 8503.49
Well -
- YES!!!
I was misled by the command name.
Thank you, Michael.
Marek
8503.51 In reply to 8503.50
BTW,
Where can I find a list of all commands as I may not know about other gems of this type?
Marek
8503.52 In reply to 8503.51
Hi Marek, in the reference section of the help file go to "Additional commands":
https://moi3d.com/4.0/docs/moi_command_reference.htm
8503.53 In reply to 8503.52
Great, thank you as I found only these here: http://kyticka.webzdarma.cz/3d/moi/ - 'List of commands without UI button' - but the older version.
Marek
As always - read the manual first...
Show messages:  1-17  18-37  38-53
