Changing perspectives in Split View
8493.1
Is it possible to change a perspective in Split View without leaving and re-entering Split View? E.g. if Top is one of my perspectives and I want to change it to Bottom, I find I have to click on Top, going full-screen on the Top view, then click on Bottom, then click on Split to restore the four perspectives, with the previous Top perspective now showing Bottom. Is there a way to do that from within Split?
8493.2 In reply to 8493.1
Hi Involute, it's possible to do that with a script on a shortcut key, set this as the command part of the shortcut key:
script: /* reverse view that the mouse is over */ moi.ui.mainWindow.viewpanel.reverseView( moi.ui.getActiveViewport().name );
8493.3 In reply to 8493.2
Perfect! Thanks.
