moi3d trial
8491.1
Hi I'm currently using the trial of moi3d and I noticed the User Interface is different from chip walters.
https://www.youtube.com/watch?v=Nr_-lyWC2aA
Do I need to buy the full version to unlock that userinterface?
8491.2 In reply to 8491.1
Hi Eric I think Chipp's interface will be different because he is using the customisation options in MOI. I think those options should still work in the trial. If you search the forums Chipp has posted quite a lot on his workflow including his interface set up.
Andy
8491.3 In reply to 8491.1
Hi Erik, Chipp has Max's CustomUI modification installed, and yes it can be installed on the trial version too. You can find it here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
MoI's UI is defined by various text files in the \ui subdirectory and it is possible to modify it by editing those files.
8491.4 In reply to 8491.3
Wonderfull! Thanks for the input. :)
8491.5 In reply to 8491.4
Hi Erik,
Here's the thread mentioned previously...
http://moi3d.com/forum/index.php?webtag=MOI&msg=7245.1
