Any way to tweak Sweep option -> ends?
All  1-3  4-6
8488.4 In reply to 8488.2
Attached is example of what I used. Projected line on to spheroid to use as rail. I initially tried the scaling rail approach but found it very fiddly, as if you duplicate and rotate the main rail there will be small sections at either end that aren't covered by scaling rail so you get a step. If you try and adjust for that I ended up distorting the curve shape.
I have had a quick go with your suggestion of a 2 rail sweep, with maintain height off and a bit of tweaking I think that may do the trick!
Andy
8488.5 In reply to 8488.4
Thanks Andy, if you can't get a good result from the 2-rail sweep please post the 3DM model file of those objects in it too. That makes it easier to maybe try out some different approaches.
8488.6 In reply to 8488.5
In case anyone else is looking at the same thing I had chance to go back and try a two rail sweep properly and it works a treat! see image.
Show messages: All  1-3  4-6
