Any way to tweak Sweep option -> ends?
All  1-2  3-6
8488.3 In reply to 8488.1
The endpointselect option is sweep factory input 4, with the factory in C code, so the simple answer is no, IMHO.
However, the sweep has history, so after the pointy sweep is made, either or both ends of the rail(s) can be extended to
a newly placed object. History then widens the tapers, so the new sweep can be trimmed to its original length, with a
larger radius. This is one simple possibility, with only limited testing.
EDITED: 23 Jun 2017 by BEMFARMER
8488.4 In reply to 8488.2
Attached is example of what I used. Projected line on to spheroid to use as rail. I initially tried the scaling rail approach but found it very fiddly, as if you duplicate and rotate the main rail there will be small sections at either end that aren't covered by scaling rail so you get a step. If you try and adjust for that I ended up distorting the curve shape.
I have had a quick go with your suggestion of a 2 rail sweep, with maintain height off and a bit of tweaking I think that may do the trick!
Andy
8488.5 In reply to 8488.4
Thanks Andy, if you can't get a good result from the 2-rail sweep please post the 3DM model file of those objects in it too. That makes it easier to maybe try out some different approaches.
8488.6 In reply to 8488.5
In case anyone else is looking at the same thing I had chance to go back and try a two rail sweep properly and it works a treat! see image.
Show messages: All  1-2  3-6
