SELECT BY GEOMETRY
8481.1
Hi is there are SCRIPT of function in MOI - RHINO has a select by BORDER command a heap of geometry can be selected by another closed curve?
any advice?
8481.2 In reply to 8481.1
Hi Alex, in MoI give the SelectIntersected script a try: http://moi3d.com/forum/index.php?webtag=MOI&msg=8088.5
8481.3 In reply to 8481.2
It's me or the Undo is not effective on the Function "Speed Randomize" on multiple objects selected? (following the thread linked post above)
8481.4
Thanks Michael - tried that one but doesnt select geometry - am I missing something?
8481.5 In reply to 8481.4
Works only with volumes! ;)
So make volumes by Extrude call script and take only bases! ;)
try the scripts by Mindset at the end of the thread but not sure of the result!
http://moi3d.com/forum/index.php?webtag=MOI&msg=8088.23
8481.6 In reply to 8481.3
Undo seems to work if you use movement or scaling but rotation seems to interfere with it. Some types of scripting can interfere with the undo system.
8481.7 In reply to 8481.6
So more prudent to save the position before the call of Function! :)
