Sweeping a hollow tube
8480.1
I'd like to create a hollow tube by sweeping along a curve. I create the curve and two concentric circles. I sweep one circle, and then the other, along the curve, but I just end up with a solid tube the diameter of the larger circle. What am I doing wrong?
8480.2 In reply to 8480.1
Nothing is wrong but you have not finished the work! ;)
Select the Big Cylinder Volume
Construct / Boolean Diff and Click the Internal Cylinder)
Et voilĂ !
For Pipes you can use some Plugins
http://kyticka.webzdarma.cz/3d/moi/#Pipe
EDITED: 18 Jun 2017 by PILOU
8480.3 In reply to 8480.2
Aah, I see. Thanks.
