Precise camera location and focal length?
All  1-7  8-12
8476.8
Great helper ! I would like to ask 3 questions here :
I have positioned the camera manually in a scene for which I want to make use of the new script now.
- How / Where can I get the exact coordinates of the camera viewpoint I placed manually ?
- Is it possible to rotate the camera around a specific coordinate (fixed / defined by a point object) ?
- If the viewpoint is infinite (horizon) just type in a very high value for Y ?
8476.9 In reply to 8476.8
Hi Tom,
Use the extended ViewAngleDialog.htm file that Brian linked to above, it's here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6962.13
The updated version adds camera xyz location controls to the 3D view angles dialog box, which you can access under Options > View > "3D view angles" button.
With the regular built in view controls MoI will only rotate the camera around the current view target point. But you could rotate it around whatever point you like using your own math calculations, see here for an example: https://academo.org/demos/rotation-about-point/
Sorry I don't understand this part - you probably don't want to put in a very high value for the camera's y coordinate since that will place your eye point very very far away from your model and with perspective foreshortening your model will be a tiny speck on the screen.
Can you explain in some more detail about what you're trying to do with the horizon?
Message 8476.10 deleted 19 Jun 2017 by BEMFARMER
8476.11 In reply to 8476.9
Hi David,
Can you explain in some more detail about what you're trying to do with the horizon?<
I want to import a scene from Cinema and coordinate the cameras. In Cinema you have a horizon
line and it is the horizon where the camera is targeted at. Is there a horizon line in Moi for the
respective focal length ?
8476.12 In reply to 8476.11
Hi Tom,
Can you show me a screenshot of what the Cinema4D camera properties look like?
I'm not really familiar with setting a camera direction by a horizon line value. In MoI the target point is what is used for controlling where the camera is looking at, it's the "look_at" point in the script above.
There does exist a horizon line for the ground plane in a 3D view in MoI but it's not something that you specify directly.
Show messages: All  1-7  8-12
