Boolean Difference random error
All  1-8  9-12
8472.9 In reply to 8472.6
Hi Sagda, yes so like Pilou mentioned that boolean behavior is because the object isn't a closed solid. The booleans determine which pieces of objects to keep and which to discard based on what solid volume they are contained inside of. When the objects aren't solids that method can't be used and instead it work more like surface trimming.
There is a script you can set up which will highlight naked edges (edges that are not joined between 2 faces) here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2798.6
In your case here though it's hard to find them because they are very small and spread out in 3 areas:
It looks like it was probably caused by filleting having some difficulty in that spot. Probably the reason for filleting having difficulty there is the surfaces here aren't quite tangent to each other:
Things that are nearly smooth like that but off by just a few degrees tends to make things difficult for filleting. That's because if surfaces meet smoothly then the fillets generated along them will also meet smoothly but if there is a crease between surfaces, the fillet pieces don't naturally end and they have to be trimmed against each other and possibly a corner juncture patch put in, but these things are difficult to calculate when the angle deviation is very small.
It should probably be feasible to repair your object and get rid of the naked edges by some strategic untrimming and retrimming, I'll give that a try.
Also there are some tips for people coming from a poly modeling background here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4865.2
8472.10 In reply to 8472.8
Hi Sagda, here is a version of your object that has been repaired to get rid of those 3 little unjoined edges to make it back into a solid. Booleans should now behave as expected again on this one.
So one thing to watch out for is try not to make curves that are almost tangent to each other but only off by a few degrees. That kind of very shallow crease will tend to make it difficult to fillet later on.
8472.11 In reply to 8472.10
thanks for the explanation, fixed file and the links(this is gold for me at this learning steps), I'm having a lot of fun learning to use moi and I really love how easy to do is some stuff in terms of just create the concept.
Have a great weekend!
EDITED: 16 Jun 2017 by SADGAS
8472.12 In reply to 8472.11
You're welcome Sadga and I'm glad you're having fun with MoI!
Show messages: All  1-8  9-12
