Displaying / Matching ends of curves
 1-3  4-23  24-28
8468.24 In reply to 8468.21
So here reduced to 2 curves.
There is a tiny gap between them.
How do I achieve that the grey one will share an overlapping point with
the red one ? I have no point to pull, so I move the 2 nearby points
with the nudge commands visually till I guess the gap is gone.
Is there a way to let MOI tell me - yes the gap is less than 0,000001 now ?
EDITED: 13 Jun 2017 by SIRTOM
Size: 85.5 KB, Downloaded: 15 times, Dimensions: 1712x1092px
8468.25 In reply to 8468.24
Hi Tom, can you please post the 3DM file too?
8468.26 In reply to 8468.22
>>@ Tom
Seems you are confused by "Control Points" and Points who are possibly on a curve!<<
Its difficult ro differentiate, I agree !
When I say "curves with a common point" I donĀ“t mean a literal curve point but the
same coordinate.
I hope the files and the screenshots can clarify my topic
8468.27 In reply to 8468.24
Hi Tom, so one way to do it would be to put in a dividing line down the middle of the gray curve, use Edit > Separate on the gray curve and then use Edit > Trim on the lower part of it to split it into 2 pieces:
You can then join the pieces together and there will now be a point that's directly on the grey curve which you can place on the red one, you'd grab that point and the inner 2 so that they all move together and keep the pieces smooth with each other:
Sorry no there's nothing set up in MoI to monitor curves for proximity after nudging like that.
8468.28 In reply to 8468.27
Ok very good, so this confirms that there is always a REAL point needed for exact placement of a curve
onto another one.
Muchissimas gracias again Michael - the MatchingScript is a fantastic time saver !!
Show messages:  1-3  4-23  24-28
