blend does not work on this object
All  1  2-18
8462.2 In reply to 8462.1
Hello,
I think there is something wrong around this area (first image).
Those 2 edges can't be merged, there must be a very small gap somewhere.
So I re-trim this area, and then blend the hole in 2 steps.
EDITED: 25 Sep 2020 by PAQ
8462.3 In reply to 8462.1
Hi vimverbe
Never say impossible
blend the two long edges
then add a center line frome each little edges ends
use the line to cut the new long blend (boolean diff)
now you just need to blend each half hole
select all, join
tadaa
possible !
8462.4
Oops sorry Paq
you're faster than me ;^)
8462.5 In reply to 8462.2
Hey PaQ,
"""""""""""""""""Those 2 edges can't be merged, there must be a very small gap somewhere""""""""""
That juncture is non tangential.
Merge will usually fill in a very small, bad trim gap. But it wont merge a corner point.
8462.6 In reply to 8462.2
Thanks PaQ, I got it now! but when I select the 2 round edges, I can join them and they become one... when zooming in very close, I can see that there is a gap...
EDITED: 11 Jun 2017 by WIMVERBE
8462.7 In reply to 8462.3
Thanks ycarry, also a very good approach!
wim
8462.8 In reply to 8462.7
Hi Wim,
As Burr said (Hi Burr !), it looks like it's more a continuity problem here than a real gap between those 2 edges.
And just to be sure, I'm talking about this merge command : http://moi3d.com/2.0/docs/moi_command_reference10.htm ... it's different from a 'join'.
8462.9
Hi ycarry,
That's a really good solution too !
8462.10 In reply to 8462.8
Hi PaQ!
I made a video for Wim on the re-trimming...
@Ycarry, works good for "tangency" only, but because the edges are disparate, if you use G2 you will get bad geometry....
But the method is cool for blending and using a divide strategy.
8462.11 In reply to 8462.10
Great Burr, I didn't think to untrim the surface before doing the new cut, good idea !
8462.12 In reply to 8462.10
Wow BurrMan,
your video taught me so many new things in a short time! thanks for that! the only thing I don't grasp is, how does MoI know that when blending the 2 long edges it takes one side only and exactly the one we are interested in at the moment? and again on the other side after that?
thanks for taking your time to do this video!c really enlightening!!!
wim
8462.13 In reply to 8462.12
Hey wim,
I'm not sure i know what exactly you are asking? If there is a time point in the video you can point to that can help describe would help.
I'll guess that you are talking about the blend of the long curves to create the new trim curves?
If thats it, then i didnt blend edges. I copied and pasted them to get curves. Then MoI has a mechanism that knows where you "pick" on objects. So by picking the 2 ends near each other, it knows those are the 2 ends i am targeting.
If thats not it, then more info is needed.
8462.14 In reply to 8462.13
Yes, that is it exactly! thanks again!
wim
8462.15 In reply to 8462.14
Shirley!!!
8462.16 In reply to 8462.15
one must be native english speaker to get that one I presume... ;-)
(surely maybe?)
8462.17 In reply to 8462.16
Hi Wim,
Sorry brother. Yes, it's a play on the word Surely.
Google "Stop calling me Shirley" will reveal my intent! (Comedy)
Take care.
8462.18 In reply to 8462.17
Hilarious! I'm a Nielsen fan! (but I didn't see this movie yet)
thanks!
wim
Show messages: All  1  2-18
