What has happened to MOI3D on my computer?
All  1-3  4-11
8461.4 In reply to 8461.3
Michael,
The problem is occurring on the 2nd computer, too. The file I closed about an hour ago will not open. I double click in the directory, when MOI opens, "Path not found" appears. File Info (Command-I) indicates it is opening with Moi v3.1.app. I reset that and no change.
I tried reducing the file name to one word and that didn't work.
From within the app, I use File>Open and the file opens blank with only the title in the upper right corner.
I got my model transferred to VectorWorks before closing the MOI file.
Leonard
8461.5 In reply to 8461.4
Hi Leonard,
Can you please send the file to me at moi@moi3d.com so I can take a look at it?
Are you sure the file actually has objects in it that MoI can use? It's possible for there to be things like many megabytes of polygon mesh objects in a 3dm file that was saved by Rhino, but that will still show as blank in MoI since MoI doesn't use that type of objects.
What is the name of the folder the file is in, that may have some effect as well not just the name of the file alone.
8461.6 In reply to 8461.5
Michael, the file, "Island," should have arrived your side. The file was created in MOI. The file's name is Island. Thanks, L.
8461.7 In reply to 8461.6
Hi Leonard, the file seems to load fine for me both on Windows and on Mac. But most of the stuff in the file is hidden, you'll need to use Edit > Hide to show all the hidden stuff if you want to see the bulk of what's taking up the several MB of file size.
8461.8 In reply to 8461.7
Hi Michael, I tried the Edit > Hide...no joy. Opening the Objects list shows "No named objects." I always name the objects in a model. The other files I had this experience with are upwards to 10X the size of "Island." –L
8461.9 In reply to 8461.8
Hi Leonard well it's very perplexing because I'm able to load your file ok over here and see object names too.
I'll follow up with you more over e-mail to try and track down what's going wrong.
8461.10 In reply to 8461.9
Thanks, Michael.
8461.11 In reply to 8461.1
For anyone else that was following this, it had to do with the .3dm files being in a deeply nested folder hierarchy. Seems like there's some limit in Wineskin on how long the directory path can be. This should be another thing fixed in v4 where Wineskin isn't being used anymore.
Show messages: All  1-3  4-11
