.3dm import problem
All  1-4  5-7
846.5
In addition to Michael's comment about the "unsmooth" torus imported into Modo - One factor is the # of polygons defining the shape. Another thing you can do to keep the poly counts low and still have good renders is set a higher smoothing angle in the objects material channel in Modo. By default it's set to 100% smoothing at 60 degrees. But you can obtain some interesting effects by adjusting it...
jonah
846.6 In reply to 846.4
yes, I missed the increase density window.
I fully understand your commitment.
I sent a 3DM & LWO file to a friend of mine tonight who uses Cinema 4D (latest version)
He says he can import LWO but not 3DM, I don't know if you aware of that.
cheers!
846.7 In reply to 846.6
Hi Tom, what's happening there is that 3DM files can actually contain both NURBS and polygon mesh data in them, it's kind of a combination file format.
However, MoI will only write NURBS data to the 3DM file, and Cinema4D will only read polygon data from the 3DM file. So they're kind of like 2 ships passing in the night in this situation.
Even though LWO works, I would really recommend OBJ format for going from MoI to Cinema4D - the OBJ format will also bring smoother shading information (vertex normals) into C4D which helps to increase render quality.
LWO is best for going into Modo or Lightwave.
Show messages: All  1-4  5-7
