Node editor UI
All  1-5  6-12
8456.6 In reply to 8456.5
Hi Barry can you please post your entire node editor folder zipped up so I can make sure I've got all the same stuff as you.
8456.7 In reply to 8456.6
file attached.
Barry
EDITED: 10 Mar 2023 by BARRY-H
8456.8 In reply to 8456.7
Hi Barry, it's because of using // for commenting out stuff in the editor.css file. Unfortunately unlike .js files, css doesn't understand // meaning a comment, it only knows /* */ for comments.
So in the .node-panel class in editor.css, when you have this:
	width: 300px;//240
	right: 0px;
it's going to think you have 2 properties there named 'width' with a value of 300px and then another one named '//240 right' which won't be recognized so essentially right: is disabled there.
If you remove the // comments or switch them to /* */ then shut down and restart MoI you should then be back to what you want.
You may have had a few other various side effects from the // comments effectively disabling the property on the next line after in other areas too.
8456.9 In reply to 8456.8
I have removed all the comment tags but still the same.
I will try installing a fresh copy of the node editor and retry editing without comment tags.
Barry
8456.10 In reply to 8456.9
Hi Barry, hmm removing the // comments worked for me over here but I did have to exit MoI and restart it, did you do that part?
Anyway if you start fresh and don't put in any // comments that should work too.
8456.11 In reply to 8456.10
Michael,
sorted it there was an old core file from a previous version of node editor still in the ui directory.
Removing that as cured the issue. Bad house keeping by me sorry about that.
I have a much more useable node editor ui now.
So again many thanks
Barry.
8456.12 In reply to 8456.11
That's great Barry, you're welcome!
Show messages: All  1-5  6-12
