how to join 2 object ?
 1-16  17-24
You have also an another strategy more easy! :)
No Rotation - only Copy Move!
From your last file
Use the Transform / Orient /Line Line / Scaling None
Sorry there is a little gap here because i didn't made a Mouse Whell Zoom for the last Click Point!
If a Zoom was made for close up the Click "Hot Point" fit is perfect!
EDITED: 16 May 2017 by PILOU
8424.18 In reply to 8424.17
Hi Pilou - Orient line to line will only work for this with certain kinds of rotations. I would recommend using orient line to line for manipulating 2D shapes on a plane, not for 3D orientations, that's what the other Orient command is for.
I've attached an example here where you can see orient line to line won't work well.
8424.19 In reply to 8424.18
I was unlucky to fall on an example who were working fine! :)
I am not yet only sure that i can't Line-line + helper lines to find a solution in any case! :)
8424.20 In reply to 8424.17
merci pilou aussi
EDITED: 16 May 2017 by NORDZWAY
8424.21 In reply to 8424.16
I am unable to view your last 3 videos.
After the colon (:), there is a large blank area
8424.22 In reply to 8424.21
Hi Brian, what web browser are you using?
8424.23 In reply to 8424.22
I've been using IE 11, but have dabbled in Chrome.
On chrome the videos show up. So it must be time to switch to Chrome:-)
Thank you Michael
8424.24 In reply to 8424.23
Or Firefox! ;)
Show messages:  1-16  17-24
