how to join 2 object ?
 1-14  15-24
8424.15 In reply to 8424.14
I thank you for all these explanations
(I know I ask strange things)
Thank you for the time you take to explain, it is a real pleasure to know that we have help like this.
8424.16 In reply to 8424.15
No problem nordzway! :)
Also here is a demo video of using Rotate Axis around the pipe's own end. To make the centerline at the start I dragged out 2 construction lines, if you drag out 2 construction lines from a common starting point it will make a "normal" snap available:
You have also an another strategy more easy! :)
No Rotation - only Copy Move!
From your last file
Use the Transform / Orient /Line Line / Scaling None
Sorry there is a little gap here because i didn't made a Mouse Whell Zoom for the last Click Point!
If a Zoom was made for close up the Click "Hot Point" fit is perfect!
EDITED: 16 May 2017 by PILOU
8424.18 In reply to 8424.17
Hi Pilou - Orient line to line will only work for this with certain kinds of rotations. I would recommend using orient line to line for manipulating 2D shapes on a plane, not for 3D orientations, that's what the other Orient command is for.
I've attached an example here where you can see orient line to line won't work well.
8424.19 In reply to 8424.18
I was unlucky to fall on an example who were working fine! :)
I am not yet only sure that i can't Line-line + helper lines to find a solution in any case! :)
8424.20 In reply to 8424.17
merci pilou aussi
EDITED: 16 May 2017 by NORDZWAY
8424.21 In reply to 8424.16
I am unable to view your last 3 videos.
After the colon (:), there is a large blank area
8424.22 In reply to 8424.21
Hi Brian, what web browser are you using?
8424.23 In reply to 8424.22
I've been using IE 11, but have dabbled in Chrome.
On chrome the videos show up. So it must be time to switch to Chrome:-)
Thank you Michael
8424.24 In reply to 8424.23
Or Firefox! ;)
Show messages:  1-14  15-24
