MoI is not working properly after several hours
All  1  2-4
8422.2 In reply to 8422.1
Hi Groot, it's pretty much impossible to diagnose any of these problems just from a written description. Please post your 3DM model file with your objects in it that are not working. Maybe you're running into something like there's an error in the model such as a self intersecting area or something similar which is affecting your operations after that.
> Early afternoon it all worked perfect, but in the last hour, it just refused to union them. I
> was able to select both triangles, but clicking on the union button just made MoI go out of
> the bolean menu.
Are you using object snaps when mirroring so you know the mirror is precise? If your mirror axis line is even just a little bit skewed then that can cause problems.
If you can post the 3DM model file with your triangles in it that were not working that might make it possible to give you some more detailed information on it.
8422.3 In reply to 8422.2
Ahhh I figured it out. I tried to cut shapes out of my mesh, after I filleted some edges, so MoI wasn't able to properly calculate the cut for those rounded edges. I recreated the mesh, made the cuts, and afterwards did the fillet operation.
8422.4 In reply to 8422.3
That's great Groot, I'm glad you figured it out. In the future if you think you've run across a bug please post the 3DM model file with your objects in it instead of only a text description or a screenshot.
There isn't really any way for me to give you any information just on a description of something like "union with triangles not working", there are a lot of possible things that could be going on like the triangles are very slightly apart from one another instead of touching, or your objects have some open edges in it instead of being a closed solid, or there are self intersections in some areas, or other things like that.
There is no way for me to figure out things like that from a written description but with the actual model file I can examine the particular situation and possibly give you some proper feedback on what's going on there. Maybe it is a bug, maybe it is something that needs to be tuned up or avoided in the geometry. NURBS modeling tends to be more sensitive to certain kinds of messy geometry like self intersections than polygon modeling.
Show messages: All  1  2-4
