MoI to 3D Coat questions
All  1-9  10-14
8415.10 In reply to 8415.9
Here are some bigger pictures. I think retopo might be difficult.
8415.11 In reply to 8415.10
Hi keith1961.
Thanks for the pictures.
If you have time take a look at this very interesting tutorials.
These guys really know what they do :)
Auto-Retopo for Hard Surface Models Pt.1
https://youtu.be/trTqnA2M9iE
Auto-Retopo for Hard Surface Models Pt.2
https://youtu.be/PoMewuVdg74
And this very interesting series :
3D-Coat Hard Surface Spaceship Wing Modeling (Part 1 to 9)
https://youtu.be/xYwhgRkdpHQ
8415.12
Hi Groot,
Here's a video showing how to bring a model from Rhino into 3D-Coat.
(substitute Rhino model for MoI model & this should help)
https://youtu.be/yPrYsARxgDM
HTH, Colin
8415.13 In reply to 8415.12
Thanks Colin, will check it out.
8415.14
MoI3D to 3D Coat.
There are a couple of ways to go. First off, you need to know if you want to retopo your model, or just import it, apply UVs, and texture it. If it's the latter, then this video will help:
If you're looking to use your MoI3D model as a 'base' for further modeling, then you'll want to export it with VERY HIGH POLY SETTINGS. Then import it into the Voxel Sculpting room as a surface model, and then voxelize it at a very high voxel poly count (multiple millions). This should give you a very smooth base to start with. Edit it using the voxel and surface tools, convert it to a surface and then use the Decimate command to reduce the number of polys (75% decimation is good). The decimate command is intelligent and will try to maintain areas of extreme detail.
You can then export it to an OBJ, reimport it, UV Map and texture. Here are a couple examples of voxel editing and exporting in this same fashion to KeyShot for rendering:
OR, if you're creating a game object, you can forgo the decimate and just retopo it (a lengthy re-modeling process) for texturing.
Here's a tute I did on UV mapping in 3DC.
Show messages: All  1-9  10-14
