Simple Circle
All
1-5
6-7
coi (MARCO)
6 May 2017 (6 of 7)
8409.6
In reply to
8409.4
quote:
Circle or even a square, I want it to be solid with out the hole.
If you, by any chance, mean something like a disk, then you just could use the planar command.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
6 May 2017 (7 of 7)
8409.7
But the disc with Planar command is not a "solid" : it's just a Surface!
So make an Extrude for add thickness ad obtain a "Solid" volume! :)
But in this case you can use directly the native Cylinder function! :)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-5
6-7
