Simple Circle
8409.1
Any tuts on circles with sweep being solid surface?
8409.2 In reply to 8409.1
Hi VaRMiT, do you mean you want to create a torus shape like a donut?
You can do that by drawing a circle and then using the Construct > Revolve command, draw the circle something like this:
Then select it and run Construct > Revolve. Pick the revolve axis off to the side of the circle like this:
8409.3
Or 2 or more circle profiles swept around a circular rail
cheers
shayne
8409.4
Circle or even a square, I want it to be solid with out the hole.
8409.5 In reply to 8409.4
Hi VaRMiT, it would probably help if you had an example image or sketch of what you're trying to do. Do you mean something like a sphere?
You can use Revolve with the axis touching the circle if you want to get rid of the hole.
Or if you want a flat area in the middle, revolve an arc instead of a circle like this:
8409.6 In reply to 8409.4
If you, by any chance, mean something like a disk, then you just could use the planar command.
But the disc with Planar command is not a "solid" : it's just a Surface!
So make an Extrude for add thickness ad obtain a "Solid" volume! :)
But in this case you can use directly the native Cylinder function! :)
