How to add picture blueprint ?
All  1  2-4
Use Menu View / Images / Add in each View you want! ( 3d, Top, Front, Right in any order)
You can after Scale , Move, Rotate with the Edit Frame
Give some parameters like Transparency, Show, Draw...
then Done!
You can now begin your normal Drawing!
If you want modify your images just return Menu View / Images
You can put any number of images!
Images can be only manipulated one by one!
Following you see View 3D, but image is drawn in View Front!
EDITED: 3 May 2017 by PILOU
8404.3 In reply to 8404.1
Hi nordzway, are you placing both the first and the second one only in the 3D view possibly? If so then that's the problem, for the elevation one you need to place it in the Front or Right view which has a vertical drawing plane.
If that's not it can you please describe in a bit more detail what is happening when you are placing the second one?
8404.4
Merci d'avoir pris le temps de me répondre si vite !
je teste ça !
Thank you ;)
Show messages: All  1  2-4
