Obj export materials have 100% specularity
All  1-4  5-8
i also use Blender for exporting to .wrl for 3D printing MoI models. I always changed the specular in Blender because of that issue. After reading your post i just switched the specular ammount to 0.0 in the .mtl and it seem to fix the problem, because now Blender shows a black color for spec instead of white.
Attached are two images for you to see the difference.
Best regards
8391.6 In reply to 8391.3
Hi Morat,
Just an idea.
Could the harsh light you have in Blender be caused by having Ambient Occlusion checked on in the World panel ?
Michel
EDITED: 28 May 2019 by VINC
8391.7 In reply to 8391.6
Hi all
I resolved this issue. When Blender creates the material on import it defaults the specular shader to CookTorr with a Hardness setting of 1, which basically means 'massive specular highlight that covers almost all the model'. Either decreasing the specular intensity or increasing the hardness fixes it.
8391.8 In reply to 8391.7
Hi Morat & Stefan, you might want to report that as a bug to Blender, it seems odd to use something that looks strange as the default.
Also maybe Blender is not paying attention to the Ns 0 line in the .mtl file, that should be interpreted as specular being off.
Show messages: All  1-4  5-8
