Obj export materials have 100% specularity
All  1-3  4-8
8391.4 In reply to 8391.3
Hi Morat, what other programs are you seeing that in other than Blender? I tested a few here and didn't see any result like that.
Can you show me a screenshot of the specific control in Blender that you're adjusting to fix it? Like is it a color value or a single percentage value? That may help me figure out what it's doing.
But I suspect it's some kind of bug in the Blender importer, like maybe they're interpreting the .obj specular color channel value as having specular actually turned on, or something like that.
If you want to test some things, try opening the .mtl file exported out from MoI in a text editor, it will have entries that look like this:
newmtl Red
Ka 0.0000 0.0000 0.0000
Kd 1.0000 0.0000 0.0000
Ks 1.0000 1.0000 1.0000
Tf 0.0000 0.0000 0.0000
d 1.0000
Ns 0
The 2 things relating to specular in there are the line starting with Ks, and the line starting with Ns.
Try removing one of those lines at a time and then both and see if that changes the import behavior.
But neither of these things should result in the type of thing you're getting, the Ks value in .obj format just controls the color that's used for specular, and Ns controls the exponent value for the specular focus, 0 should mean it's turned off. Maybe the importer is misinterpreting these values and thinking they mean something else. I don't think this used to happen, maybe it's from some recent change in Blender.
i also use Blender for exporting to .wrl for 3D printing MoI models. I always changed the specular in Blender because of that issue. After reading your post i just switched the specular ammount to 0.0 in the .mtl and it seem to fix the problem, because now Blender shows a black color for spec instead of white.
Attached are two images for you to see the difference.
Best regards
8391.6 In reply to 8391.3
Hi Morat,
Just an idea.
Could the harsh light you have in Blender be caused by having Ambient Occlusion checked on in the World panel ?
Michel
EDITED: 28 May 2019 by VINC
8391.7 In reply to 8391.6
Hi all
I resolved this issue. When Blender creates the material on import it defaults the specular shader to CookTorr with a Hardness setting of 1, which basically means 'massive specular highlight that covers almost all the model'. Either decreasing the specular intensity or increasing the hardness fixes it.
8391.8 In reply to 8391.7
Hi Morat & Stefan, you might want to report that as a bug to Blender, it seems odd to use something that looks strange as the default.
Also maybe Blender is not paying attention to the Ns 0 line in the .mtl file, that should be interpreted as specular being off.
Show messages: All  1-3  4-8
