All those additional icons in the ui?
All  1-10  11-15
8390.11 In reply to 8390.9
Hi DIMITRI,
The official CommandBar.htm is replaced with a slightly modified one, so saving the old one would be a good practice, but is not needed.
The MoI version must be a legitimate final version 3, not a beta, or version 2, or an illegal hack. ...Edit: Or free demo...
MoI ini file must refer to MoI3 path, not a beta. (An unlikely possibility.)
Windows may prevent casual install, due to your rights level...
Or do you have a Mac?
There are a couple of hundred posts, with help, under Search "CustomUI."
EDITED: 29 Apr 2017 by BEMFARMER
You have also another possibility to add icon but it's a little tricky!
In the sidePanel or in the TaskBar bottom!
in French ;)
http://moiscript.weebly.com/ajouter-une-icocircne.html
8390.13 In reply to 8390.7
Hi Dmitry, try unzipping it somewhere else like on your desktop first and then copy it over after that, it will make it a little easier to control it.
> In which, exactly, sub directory of Moi's installation folder should someone extract it?
None - you copy it over directly into MoI's main install folder. This will create 2 subdirectories in the main installation folder for "objects" and "snapshots", and it will add new stuff into the already existing UI folder. It will overwrite one file CommandBar.htm, say yes to that, that's what will make the new icons show up on the bottom bar.
If you're not seeing anything and not getting a warning about a file overwrite then maybe you've got it copied into some nested location.
8390.14
Thanks a lot all for your so patiently given answers! It is ok! The new bar is there. : - )
The version I use is the 30 days fully functional free demo. I am trying to learn the app. Seriously considering to buy it. : - )
So another headaches for have all in the same time! :)
That works but it's a very hard way for the good result! :D
Wishing the V4 will have a more friendly system! :)
Always all detailed but in French!
http://moiscript.weebly.com/customiser-lui.html
http://moiscript.weebly.com/liste-scripts-commandes.html
Show messages: All  1-10  11-15
