How to make a CAD model sculptable in ZBrush - ZBrush Live
All  1-3  4-7
Hi Pilou and all,
Metin once mentioned that he uses Styles in MoI for Polygroups in ZBrush, which works also very well.
I did a quick test and assigned random Styles in MoI with Petri's script:
script: /* Assign random styles to faces and edges */ var styles = moi.geometryDatabase.getObjectStyles(); var breps = moi.geometryDatabase.getObjects().getBReps(); for ( var i = 0; i < breps.length; ++i ) { var brep = breps.item(i); var edges = brep.getEdges(); for ( var j = 0; j < edges.length; ++j ) { edges.item(j).styleIndex = Math.floor(Math.random() * styles.length); } var faces = brep.getFaces(); for ( var j = 0; j < faces.length; ++j ) { faces.item(j).styleIndex = Math.floor(Math.random() * styles.length); } }
which you can see in picture 1.
Then in ZBrush under Preferences Import Keep Mats as Groups checked and in ZRemesher Keep Groups checked.
The quick test result you can see in Picture 2 and 3. For MoI export i used triangles only.
Excellent!
8385.6 In reply to 8385.5
An other method is to export your mesh with 'weld vertices along edges' disabled.
Then in Zbrush :
- Polygroups /Autogroups
- Geometry / Modify Topology / WeldPoints
Then you can use Zremesh with Keepgroups activated (no smoothing) like in the video posted.
Hi PaQ,
thanks for your tip, much appreciated!
Show messages: All  1-3  4-7
