If I am right seems impossible to "Add some Points" on a Face!
Does it possible to have an automatic function
Face(s) ---> Surface(s)
because it's some painful to make Move / Copy
many times on numerous faces of polygonal volumes!
I see how to add points but can you delete them or dissolve them and can you distribute them as you might want to?
I am looking for as much editable power as possible!
You can Add Lines Points to existing points.
I believe that you only move them!
You can make a sort of "Collapse" with the Edit Frame! :) (Flat)
Kill one(s) maybe by Script ? I don't know!
You can use the edit frame to squish things down flat. But generally it's not a good idea to squish individual surface points down on top of each other, stacked up control points can degrade some of the mathematical properties of a surface.
If you want to do a lot of surface control point manipulation you might look into using a polygon sub-d modeling program instead of a CAD program like MoI. Sub-d programs are really focused on that type of object manipulation. MoI is more focused on generating things from 2D curves. Although there is some support for surface point cage manipulation in MoI it's just not a focus area for it.
I understand and I am very familiar with poly modeling. Being familiar with poly modeling is probably why I liked this way of editing point by point. Thanks.
