Knolling app for nesting 2d curves
All  1-4  5-12
8378.5 In reply to 8378.4
You can use the free Algodoo! ;)
http://www.algodoo.com/
You will not have the best result but sure a physical result!
8378.6 In reply to 8378.4
Hi adamio,
> Hi Michael would it be possible to have this open source nesting tool
> integrated into MoI?
It's possible but would probably need a fair amount of work since that tool reads an SVG file and MoI does not currently generate SVG data.
Preliminary testing shows that uniconvertor-1.1.5 converts some simple svg files to pdf, which MoI can open,
to yield planar profiles.
The two font svg's did not show any content:-(
8378.8
One big feature that is missing from Moi is certainly the lack of SVG import/export support. Will be great SVG support because a lot of other softwares can easily read/write SVG.
8378.9 In reply to 8378.4
adamio
Hi Michael would it be possible to have this open source nesting tool integrated into MoI?
http://svgnest.com
https://github.com/Jack000/SVGnest
Nice finding. Thank you for sharing.
8378.10 In reply to 8378.9
There are several thousand lines of code :-(
EDITED: 1 May 2017 by BEMFARMER
After much puzzlement, and web search, here is how to use SVGNest with input created from MoI3.
1. It is convenient to use the TOP view in MoI3, to create 2 dimensional objects.
2. In MoI, create one larger box, called a "bin" to hold the 2 dimension shapes which
are to be nested. The bin can be a rectangle, or a polygon such as a hexagon, or an ellipse.
3. In MoI, create the desired 2d objects which are to be nested. These objects can
include Text in curve form, and polygons such as squares and triangles.
4. Save the MoI bin and objects as a PDF file.
5. Import the PDF into Inkscape, and save as SVG.
6. Open Google Chrome web browser, and enter http://svgnest.com/
Hit the Upload SVG button on the SVGnest.com screen, inside Chrome,
to load the SVG file that was saved from Inkscape in step 5.
Select the bin box created in step 2, then hit the Start Nest button.
7. After a few nesting iterations, hit the Stop Nest button.
Then hit the Download SVG button. The nested SVG name appears at the bottom left of the screen.
Select this nested SVG file name, and save the file.
The saved nested file can be loaded back to Inkscape, and saved as PDF.
8. The saved nested PDF can be opened in MoI. The scale was magnified by 2.144...
EDITED: 2 May 2017 by BEMFARMER
Aspire will open a MoI pdf, and nest the 2d objects.
Show messages: All  1-4  5-12
