About Make2D
All  1-8  9-15
8368.9
Thanks for the script.
It doesn't work as i expected and my needs. It create just one layer (Konstruktion) combining both the Visible lines AND Hidden lines.
What i was hoping for was 2 separate layers: One layer for Visible lines and a second layer for Hidden lines.
Anyway, thanks for your effort. Let's wait for the v4 betas and i'll talk to you about this.
The way that actually the Hidden lines Layer is created (i mean on Make2D and Make2D4views) i assume that could be easy/fast/possible to script a 2nd layer.
Thanks alot.
Carlos
8368.10 In reply to 8368.9
Hi Carlos, actually that was Hep that wrote that script for you, not me. I didn't think about a script fix up like that, but I think it should be possible to get what you want by a modification to Hep's script there to avoid processing the hidden lines. I'll give that a try tomorrow.
Thanks Hep for the script that is very close to the desired result!
8368.11 In reply to 8368.8
There's also a findStyle script method that's probably useful for part of this, it has a "Create if not found" parameter like this:
var style = moi.geometryDatabase.findStyle( 'stylename', true /*CreateIfNotFound*/ );
8368.12
Hello Hep,
I'm sorry. Thanks a lot for the script!
Carlos
8368.13 In reply to 8368.12
Hi Carlos, please try this version. Run it just after you use Make2D and it should move just the visible lines that were generated onto a style named "Visible lines". Thanks Hep for sharing your script to get started.
script: /* Move Make2D visible lines to their own layer */ var gd = moi.geometryDatabase; var hdn = gd.findStyle( 'Hidden lines', true ); var vis = gd.findStyle( 'Visible lines', true ); while ( vis.index > hdn.index ) vis.moveUp(); var objs = gd.getSelectedObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.styleIndex != hdn.index ) { obj.styleIndex = vis.index; } }
8368.14
Hello Michael and Hep,
Thats is fantastic! It is exactly what i need. Great, just great support and community.
It makes a huge difference have direct contact with the developer and a healthy community willing to help.
Thanks a lot.
Carlos
8368.15
Hi Michael and Carlos
I am happy i could contribute a bit to this fantastic program and forum.
Moi3D is just a joy to use :-)
//Hep
Show messages: All  1-8  9-15
