Hi Carlos, please try this version. Run it just after you use Make2D and it should move just the visible lines that were generated onto a style named "Visible lines". Thanks Hep for sharing your script to get started.
script: /* Move Make2D visible lines to their own layer */ var gd = moi.geometryDatabase; var hdn = gd.findStyle( 'Hidden lines', true ); var vis = gd.findStyle( 'Visible lines', true ); while ( vis.index > hdn.index ) vis.moveUp(); var objs = gd.getSelectedObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.styleIndex != hdn.index ) { obj.styleIndex = vis.index; } }
