Consider using Google's Guetzli Encoder when posting images. ;-)
All  1  2-10
8363.2 In reply to 8363.1
...and for squeezing other attachments like .zip we could also consider Google's
Brotli or Zopfli file compressors. ;-)
Something i don't undersand
I load your first image and save as JPG old fashion (90 %)
I obtain an image 75.000 KB against your 188.445
1 first April ?
EDITED: 31 Mar 2017 by PILOU
i was talking about "high-quality"... So please try again with 100% instead of 90%.
When i use 100%, depending on the software i use, i get between 300+K and 500+K.
8363.5 In reply to 8363.4
for your image at 100% : 292.167 ;)
Cool, that sounds good.
O.k. another test with Google's Zopfli, in case people
don't like jpeg...
Same image with Photoshop as .png = 736.661 Byte
then pngcrush = 660.358 Byte
and pngcrushed image used with Zopfli = 631.517 Byte
Source Code: https://github.com/google/zopfli
i wonder if you or anybody else can open also
my attachment without any problems. I used also
Google's Zopfli to compress the file instead
of .zip. Maybe i use it too in the future for
attachments if everybody can open it.
Zip file = 909.779 Byte
Zopfli = 895.999 Byte
O.k. Pilou, i checked the --help entry and Guetzli defaults to 95%...
With 100% it would be 476.217 Byte
and with 90%, like you did, it would be 84.770 Byte.
I'm curious now what you would have with 95%?
You must have a very good encoder for Windows! :-)
P.S. just found ImageOptim for Mac, wich contains
Zopfli too. https://imageoptim.com/mac
8363.9 In reply to 8363.8
With my old one i have 122.016 at 95 %
If you speak about BatWing attachment no problem to uncompress with 7Zip! :)
EDITED: 1 Apr 2017 by PILOU
Thanks for the info Pilou, much appreciated!
Show messages: All  1  2-10
