mesh wishes for 1.X and beyond
 1-16  17-23
836.17 In reply to 836.16
> Would such control be possible in MoI ?
I don't know - it is pretty hard to imagine how to control that without a pretty elaborate UI...
Some programs can automatically calculate this kind of separation for you in their UV editors, for example I'm pretty sure someone has mentioned Blender can do it. But I'm not familiar enough with its UV editor to be able to give you the details.
836.18 In reply to 836.17
Yes, you can usually do that in UV editors, by selecting the parts you want to UV and where the seams will be. I was more thinking at some sort of "pre-process" during the creation of UV map with UV nesting. It's some sort of "lazy" solution... ;-)
836.19 In reply to 836.18
mmm. lazy good. work bad... :)
836.20 In reply to 836.18
I think you should already have a natural seam in the UV coordinates for all the polygons that make up each face in a solid. Like for instance when you have a cylinder, UV coordinates are not shared along the seam of the cylinder, only 3D points are shared there. I wouldn't think you should have to manually specify seams.
Anyway, it would definitely be more convenient to have this done automatically instead of needing to do an extra editing step.
That's kind of one of the additional nice things of using a NURBS modeler, since every NURBS surface has its own UV space you get a UV mapping for everything automatically.
836.21 In reply to 836.4
Hi Jonah, that file-overwrite-on-cancel bug you reported earlier in this thread is fixed in that latest patch update.
836.22 In reply to 836.21
very cool! thanks Michael...
jonah
836.23
i just noticed that Modo 301 will have a UV nesting function called "UV Pack". So that's good news for export Moi meshes...
jonah
Show messages:  1-16  17-23
