Creating custom colours (styles) on start-up
All  1-2  3-6
8359.3 In reply to 8359.2
Awesome. Thanks.
Sebastian
Question on displaying the full path name to the Template File: (I've had to hunt for it in the past)
My template file, (Windows7), is located at c:\Users\*****\Appdata\Roaming\Moi
Under Options General, only the Compact path is displayed: C:...\MoiColorSave2015cm.3dm (my name for the file)
The relevant code for the path seems to be lines 31 and 215 of the file "GeneralOptions.htm" in the MoI ui directory.
I increased line 215 from 18em to 36em, which adds whitespace to the path box.
I increased the number in line 31 from 29 to 64, which only very slightly increased the path shown.
Line 31 refers to ".getCompactPath( filename, 29 );"
Is there an alternative to ".getCompactPath" ?
(I tried .getPath and .getFullPath, but they did not work.)
Or is there some way to display the full path name to the Template File?
8359.5 In reply to 8359.4
Hi Brian, you can just use the filename directly instead of calling .getCompactPath().
Current code is like this:
				var filename = moi.geometryDatabase.startupTemplate;
				if ( filename != '' )
					g_TemplateShortName = moi.filesystem.getCompactPath( filename, 29 );
You'd want to switch it to this instead:
					g_TemplateShortName = filename;
Hope that does what you wanted!
8359.6 In reply to 8359.5
Thank you very much Michael.
I also changed line 251 from 18em to 36em
(The path I gave above was not quite correct :-)
Show messages: All  1-2  3-6
