Wrap Curve To Cylinder, Pitch Blend Helices
All  1-4  5-10
The UnwrapCylCurve script is now working well, using the formula in the previous post, but with a few problems.
Corner points, i.e. angles, between two joined curves cause wiggles, even with high point count. 2000 points is less wiggly than 500 points.
(Tight bends would probably also have wiggles.)
Is there some way to identify corner points?
Separate seems to do it.
Using separate and getStartPoints and getEndPoints may be a work around, with each segment arrayed separately.
The cylinder axis must be parallel with the z_axis.
Only one curve, which can be joined, is done at a time.
A curve on a cylinder may be unwrapped, or unwound, with the _UnwrapCylCurve script.
Documentation and description is contained in the script .js and in the .txt files.
Three test files are in the Test3dmFiles zip, including "un" FLOW of intersecting cylinder, which is very close to the unwrapped intersection.
Script deleted 4/14/2017
It works well for certain curves, but needs more work for non-helical, doubling back direction curves...
I may post it again after some changes. (Only 3 downloads.)
EDITED: 14 Apr 2017 by BEMFARMER
8357.7 In reply to 8357.5
Hi Brian, aside from using separate another way to gather corner points would be to get the list of segments of the curve, that's available by calling the .getSubObjects() method on a curve. Then on a segment there are also getStartPt() and getEndPt() methods same as there is on the parent curve. So something like this:
var segs = crv.getSubObjects();
for ( var i = 0; i < segs.length; ++i )
var seg = segs.item(i);
var pt = seg.getStartPt();
8357.8 In reply to 8357.7
Thank you Michael.
That code should work well.
8357.9 In reply to 8357.7
EDITED: 18 Apr 2017 by BEMFARMER
Here is version 5 of UnwrapCylCurve, which works well, and required quite a bit more work.
Michaels angle script was used to calculate arclength, with better accuracy.
Processing each segment of a joined curve was done by using Michaels forum posted code.
Unwrapped segments have not been rejoined.
Unwrapped location depends upon curve start point. Incorporating bounding box center may improve this.
Comments are in the .js.
Test curves included joined helices of different pitch and handedness, as well as cylinder projected, circle and pentagon and small curve.
FLOW may be used to unwrap cylinder curves that are less than a single turn, using base profile circle and unwrap circle.
Such a Flow unwrap is slightly larger than an UnwrapCylCurve version, but the two unwrapped curves agree very well to a few decimal places and zoom_in's.
The curve needs to be on the cylinder, a planar curve will probably yield no results...
A test ellipse in the top view, rotated in the front view, did yield a "boat hull cross section-like curve."
The script is a bit slow. It takes about 1 second per 100 numpoints, per segment.
EDITED: 21 Apr 2017 by BEMFARMER
Show messages: All  1-4  5-10
