Mesh gets hollow after a few cuts
All  1-12  13
8352.13 In reply to 8352.11
Hi Defonten,
> Thanks a lot Michael, but could you pls clear this untrimming process up a bit more for me? I try to
> get rid of those edges and they're just won't be deleted. What am I doing wrong?
You're probably selecting just one edge and hitting delete - instead you have to select an entire trimming boundary and then push delete. A quick way to select the entire boundary is to select one edge and then use Ctrl+A for select all.
If you have a version of this file with your original curves in them you used to boolean against you can just copy/paste that over instead of doing the untrim.
Show messages: All  1-12  13
