Hi Alex, when MoI starts it will look for moi.ini in either the same directory as moi.exe or in your user data folder (on Windows that's in %AppData%\Moi\moi.ini).
When it's initially created it puts it in the user data folder.
It's also possible to put it in any location of your choice if you tell MoI where it is by passing the moi.ini file name with full path as a command line parameter to MoI.exe, surround it with quotes " " if there are any spaces in the path.
