Tool Tips vs Text Labels
8338.1
For those of you who would like a popup TOOLTIP in place of TEXT LABELS -
sidePaneToolTipCode.zip contains my html page already coded -
Save your current SidePane.htm as (e.g.) SidePane001.htm - then replace it with the one in the ZIP FILE.
You can CHANGE what appears in the TOOL TIP
Remember to add the code at the end to close the code - it's different end code for the folder LABEL -
Examples below:
8338.2
When reducing the buttons to Folders aren't you just adding extra mouse clicks to get at the command you want ?
When it is reduced to a folder , you have to open it to get at the command then click it. Two or three clicks when 1 would do.
It seems like extra work to me. Part of the genius of Moi is that you can get straight to the most used functions.
I would not like it to turn into rhino where you have to wade into popups or menus to get anywhere.
cheers
shayne
8338.3
I was toying with the idea of reducing all the commands in the folder into a toolbar - ideal would be a floating toolbar - take up less real estate
