Looking for suggestions on how to model part
All  1-7  8-11
8336.8 In reply to 8336.7
Looking good twofoot!
The joints at the second horizontal line from the bottom see slightly non-tangent, and perhaps could have a small segment trimmed out,
and be re-blended? Or maybe it is an optical illusion.
Just in general, I've noticed some old blueprints seem to have small non-symmetries, and small inaccuracies.
Did you use shell?
8336.9 In reply to 8336.8
Hey Brian. There are a number of different extrusions that will occur before it become a fully modeled, 3D piece. That might account for the inaccuracies you mention.
Yes, there are tiny differences to be found in old blueprints. After all, they were done by hand! We take for granted .000001" accuracy, and use it even when it isn't really needed.
One thing I have learned working with these old documents, "back in the day", they were a lot less about aerospace tolerances and more about proper function and longevity. Most times a 1/32" was "good enough".
Chris
EDITED: 20 Feb 2022 by TWOFOOT
8336.10 In reply to 8336.9
I doodled on it...
8336.11
Hello,
Similar to Burrmans technique, you might also find it helpful to create horizontal and vertical lines, Blend between those lines, and then nudge the lines so the blended curves fall into place.
Show messages: All  1-7  8-11
