You can place <!--Beginning of the EDIT tab--> & <!--End of the EDIT tab--> around each TAB section - and change the code like this to enable popup tool tip balloons.
After carefully re-reading Max's instructions for adding objects to the Object Library, http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
please note that the Object Library command will automatically create a png "thumbnail" of an object on the MoI screen,
as well as save the object. Your choice of lighting options can be pre-selected.
