Add Objects to Solids Folder
All  1-4  5-8
Message 8335.5 deleted 3 Mar 2017 by BEMFARMER
8335.6 In reply to 8335.4
Hi Ced, there are several commands on the Solids palette that you'll now be missing, like draw cylinder, draw plane, create text.
So I wouldn't recommend removing that.
8335.7
Hey guys! Look - here's how to add a TOOL TIP (balloon) which makes it convenient when you're looking for a tool~!
Pops up everywhere you hover -
<moi:Text textid="">Edit
You can place <!--Beginning of the EDIT tab--> & <!--End of the EDIT tab--> around each TAB section - and change the code like this to enable popup tool tip balloons.
EDITED: 3 Mar 2017 by FRACTIONALIST
After carefully re-reading Max's instructions for adding objects to the Object Library, http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
please note that the Object Library command will automatically create a png "thumbnail" of an object on the MoI screen,
as well as save the object. Your choice of lighting options can be pre-selected.
Show messages: All  1-4  5-8
