Add Objects to Solids Folder
All  1  2-8
8335.2 In reply to 8335.1
Hi Ced,
Why not use Max's Obj Library folder.
It shows up on your MoI screen picture...
In that folder, I've go a tetrus, icosahedron, etc...
8335.3 In reply to 8335.1
Hi Ced, like Brian writes above it looks like you've already installed Max's CustomUI extension, so you have a button on your bottom toolbar labeled "Obj Library", it's for doing exactly what you describe.
The way you've tried to add it there is as a drawing command, a command is made of script code that does things like pick points, a .3dm file on the other hand is a data file they are not the same thing.
It could be possible to set up a button like you're trying to do but you'd need to make it use the import command with the 3dm file as a parameter to it, like command="Import c:\objects\myobj.3dm" . But since you have the "Obj Library" button all set up on your bottom toolbar already you should give that a try first.
8335.4
Thank you! Perfect~! Removed the Solids or Shapes folder - which I had renamed 'Objects' folder from the menu~!
You can give me a solid for that!
Cheers,
Ced
Message 8335.5 deleted 3 Mar 2017 by BEMFARMER
8335.6 In reply to 8335.4
Hi Ced, there are several commands on the Solids palette that you'll now be missing, like draw cylinder, draw plane, create text.
So I wouldn't recommend removing that.
8335.7
Hey guys! Look - here's how to add a TOOL TIP (balloon) which makes it convenient when you're looking for a tool~!
Pops up everywhere you hover -
<moi:Text textid="">Edit
You can place <!--Beginning of the EDIT tab--> & <!--End of the EDIT tab--> around each TAB section - and change the code like this to enable popup tool tip balloons.
EDITED: 3 Mar 2017 by FRACTIONALIST
After carefully re-reading Max's instructions for adding objects to the Object Library, http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
please note that the Object Library command will automatically create a png "thumbnail" of an object on the MoI screen,
as well as save the object. Your choice of lighting options can be pre-selected.
Show messages: All  1  2-8
