Hi Tom, there isn't really any set of moi.ini settings to configure - for using a tablet there is an alternate set of viewport navigation tools in the viewport toolbar that's underneath every viewport, this one here:
Those buttons allow for pan, rotate, or zoom using just a press and drag of the stylus without needing to use different buttons or key combinations. They are more sensitive than the regular mouse button controls so you only need to move the stylus a small distance to make the view change happen. So for example to rotate press the stylus down on the Rotate button and move it a little bit to the left and right.
But you don't need to do anything special to enable these controls, they are enabled by default, they are just an alternate way to do navigation in addition to things like middle mouse button drag, right mouse button drag, scroll wheel, and multi-touch.
Maybe I didn't understand what it is that you're trying to set up though.
