Export Closed Curves to Inkscape? Mine are exploding!
All
1-2
3-5
Michael Gibson
22 Feb 2017 (3 of 5)
8326.3
In reply to
8326.1
Hi FDP, which version of Inkscape are you using? Also can you post a 3DM model file with the curve that is not being closed in Inkscape? Another thing is you might try PDF format and see if that helps any.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
FDP
16 Mar 2017 (4 of 5)
8326.4
In reply to
8326.3
The solution was to use PDF!
FDP
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
16 Mar 2017 (5 of 5)
8326.5
Same if you use the fantastic low price Affinity Designer! ;)
Pdf is the Key Moi to Affinity Designer!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-2
3-5
