group/ungroup
 1-14  15-23
8321.15 In reply to 8321.13
Great tip Pilou but I can not reproduce it. After you select the two lines what tool do you select?
I selected the line tool and I can draw the construction line but I can not move everything inside the circle.
-Martin
Edit: I think I finally got it. You use the move tool, draw the construction line and then pick the base and the target point.
EDITED: 21 Feb 2017 by MARTIN3D
8321.16 In reply to 8321.14
Hi glmr, another option is to use the Transform > Move command with the "Bounding box center" option as the basepoint. To do this, select your lines, run Transform > Move and at the first prompt where it asks you to pick your base point, there is a button available labeled "Bounding box center". Push this button now to use the center of the selection's bounding box as the base point for the move. Then click the target point at the center of the circle.
Also the Transform > Align command should work for that with the "Move as group" checkbox enabled, if that is not working as you expected can you please post an example file so I can see exactly what is going on there?
For example with this:
Running Transform > Align with the "Move as group" checkbox enabled will give you this:
8321.17 In reply to 8321.16
maybe I use command in wrong way. so, I have group of two lines (g1) and circle. when I use ALIGN selecting group and circle they are moving together without changing their mutual position if I checked "move as group" box.
so, looks like I do something wrong, but I can't understand what is wrong.
anyway - I would be happy to have a script or command which allows to work in "traditional" way
8321.18 In reply to 8321.17
Hi glmr, so for a case like that where you want to align 3 objects but keep 2 of them as a group (the lines) and the other one (the circle) also aligned to some other spot but treated individually, you will need to use the Align command in 2 separate passes. Do it once with the 2 lines selected and "Move as group"' enabled, and then a second time on the circle. Does that produce the result you want? Or you could use it once on the lines to align them to the circle, then select all 3 objects and run it again to align the whole set to your end destination.
I do want to add a grouping function so you could group your lines and have it behave how you originally expected.
If you're still unsure on how to use the Align command in 2 separate passes to get what you need, please post the 3DM model file that has the objects in it that you are using so I can show you with your actual file.
8321.19 In reply to 8321.18
thanks! looks like I understood how it works and now I can avoid export to another software.
but generally I would like to work with groups of multiple objects as with single objects. this is "traditional" way and I hope you will add this feature or script, or command.
8321.20 In reply to 8321.19
Hi glmr, I definitely do want to add a grouping feature, but it will have an impact on how a lot of commands process things and modify basic behavior such as how selection works.
Something with that broad of a scope isn't really feasible to do with a plug-in or script right now, it will need to be implemented more in the core of MoI.
8321.21 In reply to 8321.20
maybe it would be enough Photoshop concept of grouping layers for v4.
Mik
8321.22 In reply to 8321.21
Hi Mik, I think that type of grouping will be useful in addition to the "select as one" type of group. So I think I'd like to do both. The folder style grouping like you show there could be good to have in any scene browser section.
8321.23 In reply to 8321.22
yes, folder style grouping will be helpful for Objects and Styles as well.
Mik
Show messages:  1-14  15-23
