Specific length between two lines
 1-10  11-27
8319.11 In reply to 8319.10
@Burr
You have not the red point on the left who can be anywhere! :)
In reasonnable position / of the black A segment given !
8319.12 In reply to 8319.11
Your picture is missing information, unless the dotted line from the point denotes a "new angle value". Which then changes the length of A. If thats the case, B is a single intersection move point and C is derived in a rotation from B as its center.
But i didnt get that he was "modifying" his lines length and rotation. At that point, just draw a line with the "given"
My image has all informations!
In fact the solution will be to draw a line from any red point and cut the 2 sides of the black angle
on B & C with the exact length of the segment A. (red A' = A)
Alas geometric tools given by Moi today are not sufficient for make that!
Of course black segment A and red point on the left can be any thing reasonnable!
Tool is asked! :)
For this red point and this black segment that is evident !
but for another red Point with same segment? Or / and another segment? .... ;)
EDITED: 20 Feb 2017 by PILOU
8319.14 In reply to 8319.13
But your "given can be anywhere" is incorrect, because distance "A" is limited....
Post your file!
8319.15 In reply to 8319.14
<< because distance "A" is limited
I said a reasonnable length / Point ;)
we have yet infinite possibility with my image of the previous post with this "trivial solution"!
A = 4,472136 unity in this case
If you take A = 5 and same point...you must find another angle...for cut...
Here a file but you have no need a file! ;)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/a_solution.3dm
8319.16 In reply to 8319.3
Hi Tyler ok sorry I didn't understand fully before about keeping the line at the same angle.
If I understand you correctly now, you can use the Transform > Move tool to do that if you set up a construction line to help get the snap point you need.
You'd start by putting the line onto one of those lines like this:
Select the line to move and run the Transform > Move command. Now you need to set up a construction line like this to help you get the snap you want:
The way you make a construction line is to press the mouse button down and keep it held down while you are dragging it. You want to snap the ends of the construction line onto the ends (or anywhere is ok) of the upper line that is being touched already. So you'll initially have the construction line going right over top of that line. Now you want to move that construction line over, you can do that by pressing and holding the mouse button down for 1 second or so on the little chevron that pops up, see here for more details:
http://moi3d.com/3.0/docs/moi_command_reference11.htm#constructionlines , on the menu that pops up after holding down the button there, choose "Relocate cline" and you'll be able to move the construction line to a different area while keeping it in the same orientation. This way you can basically capture a direction and apply it to a different spot.
After your construction line is relocated to the other end of the line being moved, you then want to use these 2 snap points for the Move command:
Hopefully that is what you needed? Please let me know if I still did not get it quite right though.
@Burr, is there something I need to look at for the youtube embed codes still?
8319.18 In reply to 8319.17
Hi michael,
Well, not really for me, but you may want to look at that for the forum later. Here's the jist:
Youtubes embed is an iframe code tag when "not logged into a youtube account".. when "logged in" they seem to be wrapping it in html5 div container, which no longer embeds in the forum properly. I left my first post with this code intact so you can reference it if you wanted.
So, i dont really need anything anymore. Its just a note for you now... thanks
8319.19 In reply to 8319.15
Just got back from an evening fishing sesh with my brother. No fish. Bankrupted the lead and hook! Insane sunset!!!!
8319.20 In reply to 8319.19
@Burr
I will study that!
If it's a task as I suppose : you will be my hero!
8319.21 In reply to 8319.20
No, it doesn't work out that way.
""""""""""What if the number is 5?""""""""""""""
It really is more of a SIM calculation and not something CAD really does.
Maybe this is something MAX can tackle with Node Editor. Something like Anchor constraints need to be applied to use the basic snap mechanics. But it will be complex. He may have to look at some type of library to integrate....
@Burr
I follow your explanation but seems with this file I must miss something! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/b_solution.3dm
<< Something like Anchor constraints need to be applied to use the basic snap mechanics.
Yes! In this case double anchors! (or maybe a very tricky geometric construction - that i wish of course! ;)
(geometric because mathematical is not yet very cumfortable for my very old neurons! :)
EDITED: 21 Feb 2017 by PILOU
8319.23 In reply to 8319.16
You guys are AWESOME! Thank you so much everyone for your kind help, knowledge and experience. Haha, I am embarrassed now because it is such a simple (and obvious) solution!
Thanks again Michael, really appreciate your very simple explanation of a fairly complex action.
I love the simplicity of MoI and completely agree with Michael that it needs to be a strict focus to keep it simple rather than clutter it with complicated UI. The things achievable with MoI already surpases many other 3D applications for modelling. Keep up the great work!
Looking forward to purchasing v4.0 ;)
8319.24 In reply to 8319.22
""""Or maybe a tricky geometric construction"""""""
Unfortunately it wont be one of those. It will have to be 2 anchor points that can slide around, in real time.
8319.25 In reply to 8319.1
hi
For this kind of problem, i use SOLVESPACE witch is a free 2D and 3D solver.
Chri
8319.26 In reply to 8319.25
Sure i know that!)
see my French site :) (that I must update! )
http://moiscript.weebly.com/solvespace.html
but it is a shame that a simple geometric construction don't make this simple thing!
Before a tricky plugin or anchor(s) function!
It's a delicious headache for insomniac! :)
8319.27 In reply to 8319.23
Hi Tyler,
You're welcome, I'm glad that does what you needed! But yes if you have too many more constraints like "keep this angle", "this must be equal to that", "at a specific length" you can get into things where you can't really draw it by picking points or extending lines like you could in this case. For those things a solver is needed and Solvespace is a nice one for that.
I do still hope to be able to add constraints into MoI eventually as well too.
Show messages:  1-10  11-27
