Script for generating Wires
All  1-6  7-12
8311.7 In reply to 8311.5
Hi Mindest!
Thanks for the appreciation!
Here are the scripts you asked for.
1) These are the two original scripts written by Michael.
Download the zip file from http://take.ms/6EIBk
Unzip and copy the two .js files into the Moi's "scripts" folder.
2) And this is the modified version that I wrote some times ago.
Download the zip file from http://take.ms/4Pgky
Unzip and copy the four files into the Moi's "commands" folder.
These are the main difference between the original Michael's scripts and my :
1) Michael's file are two .js placed into the "scripts" folder and they are not executed into the Command Processor environment.
This mean that they aren't treated as an "atomic" undoable operation.
And, more important, these scripts move ALL the selected objects, under or on ground, considering the global BoundingBox that contains all that objects.
2) My version is composed by four files placed into the "commands" folder and in this way they can be executed into the Command Processor environment.
This mean that they are treated as an "atomic" undoable operation.
And these commands process all the selected objects but move EVERY single object INDIVIDUALLY, under or on ground.
All these things are clear if you watch this short video : http://take.ms/mjPfT
See you!
8311.8 In reply to 8311.7
Wow thank you Marco!
I love this forum and of course MOI.
For sure let us know if you ever decide to share your UI enhancements - they are extra fine.
It was especially nice of you to take the time to make the tutorial.
Thank you Marco!
8311.9 In reply to 8311.8
Hi Mindset and thanks again for your appreciation.
@You : "For sure let us know if you ever decide to share your UI enhancements - they are extra fine."
Well, as I said some month ago, I hope to have some decent amount of extra spare time to clean up a little bit
my whole Moi application folder, and once that is done, I will publish my whole Moi, as is, also with all the hotkeys and setup,
and with all the UI and plugins you see in my video.
It will be my personal gift to the community :)
See you.
8311.10
Here's a little clip how to make wires: https://youtu.be/F4EZ2LvdrIE
8311.11 In reply to 8311.10
Hello,
Flow - Twist - FLow
- You can build this kind of wire in 2 minutes in MoI, using the flow function.
In poly-modelling world, a good method is to use curve deformation tool, or UV conform technique .... way less destructive than the direct modeling approach from this video.
EDITED: 16 Jan 2023 by PAQ
8311.12 In reply to 8311.11
Hi PaQ!
Very nice and interesting stuff! Thanks!
Show messages: All  1-6  7-12
