Blend Construction Lines
All  1  2-3
8309.2 In reply to 8309.1
Maybe Construct / Curves / Iso / U ?
Better if you can post your 3dm file! :)
8309.3 In reply to 8309.1
Hi Berube, that's just how Blend is designed to work, it tries to make one smooth surface if possible, treating a tangent series of input edges as if it were one long continuous curve.
> which could prevent me from running a chamfer across my whole object per say.
I don't think you'd be able to put a chamfer through that area you show anyway since you can only chamfer sharp edges, you can't put a chamfer in a spot where surfaces are smooth where they touch each other.
Show messages: All  1  2-3
